View Poll Results: TFPrime Remote Control W1&2 - worth buying?
- Voters
- 3. You may not vote on this poll
All yes
One or two
None are worth it
Not even interested
26th June 2012, 01:27 PM
#1
Toy Review - TFPrime Remote Control Wave 1 & 2
(Please post photos, comments or even a fully comprehensive review - these are just brief details to get you started)
Since the first two waves came out at almost the same time here, and each is not likely to draw much interest from the more seasoned collectors here (and TBH, these are pretty lame by RC standards), the three figures are being grouped together to save "space".
Knock Out
Series - TFPrime
Sub-line - Remote Controlled
Size/class - n/a
Wave - 1
New/remould/redeco - New
Released here - June 2012
Approximate Retail Price - $38-45 (US$20)
Approximate Size - 14cm
Allegiance - Decepticon
Alt-mode - Car
Main Features/Gimmicks - Remote Controlled forward movement*, and transformation.
Main Colours - Red, maroon, grey, yellow.
Main Accessories - Controller.
(Requires 4x AAA batteries)
* NOTE - toy only has forward movement in both modes. The Transformation has the toy rotate, which is the only way to change your forward-direction. The remote-controlled transformation (gimmick) has sacrificed any backwards or turning ability that previous RC Transformers had. The only (slightly) redeeming factor with this figure is that when it is moving forward in robot mode, the upper body does a slight twist as if the robot is punching while "running". The drawback though, you need to be fully transformed, which will leave you pointing in a set direction that you can't change before moving forward.... and if you aren't fully transformed before you move forward, it will often just fold back up into vehicle mode.
Bumblebee
Series - TFPrime
Size/class - n/a
Wave - 1
Allegiance - Autobot
Alt-mode - Sports Car
Main Colours - Yellow, black, grey
Wave 1 pair in-store...
Optimus Prime
Series - TFPrime
Size/class - n/a
Wave - 2
Alt-mode - Truck
Main Colours - Red, blue, grey.
(official image will be added when I find one)
- You may not post replies
- You may not edit your posts
Forum Rules
